Basic and advanced features
Features
Below is the list of all the features available in reWASD. All of the features are a part of the Lifetime access. All of the advanced features are a part of the lifetime access as well.
Legacy basic license features:
Legacy basic license includes a list of features that in versions before 8.0 could be purchased as a part of a basic(legacy) license:
Advanced features
Advanced features are divided into five groups.
Advanced mapping — this feature permits hardware controller tuning: get the access to Native mapping section, mute the native controller input with the help of Mute, change Advanced stick settings, adjust Zones for Triggers, make controller button combos, use physical mouse as a Right stick, adjust the Vibration settings for your controllers. Enhanced Mouse Mute improves how reWASD handles mouse input to provide smoother performance and reduce latency. It helps ensure a consistent response to remapped mouse actions.
Note that a part of Advanced mapping feature is available for Xbox Elite, One, One S and Elite Series 2 with the basic license only. However, you will still need this feature to mute stick directions, set custom stick response, make controller button combos or assign mouse directions to virtual sticks no matter which controller you use.
Combo — this feature allows you to create combos with both keyboard and controller button presses, we strongly recommend to get acquainted with the Combo Editor.
4 Slots — this feature permits you to assign 4 different configs to one controller and switch between them by using a customizable shortcut
Custom Crosshair — allows you to create and customize your own crosshair overlay and optionally enable a dynamic screen magnifier, making it a perfect tool for gamers seeking an edge in accuracy and control.
Send Input — allows you to remap input generated by on-screen keyboards by assigning actions directly to the keys of the Send Input device.
Rapid Fire — this feature allows applying Toggle and Turbo to any mapping. It also allows you to use Jump to Shift buttons in Toggle and Custom modes.
Radial Menu - is an advanced feature within reWASD, facilitating a streamlined command access system in your preferred games or applications. This functionality empowers users to efficiently access frequently used commands by grouping them in the main menu or submenus. Offering universal compatibility, the Radial Menu supports all types of controllers.
Mobile Controller — use Android or iOS device as gamepad with the help of reWASD Mobile, and apply numerous reWASD features to customize the layout exactly the way you want.
Analog Key Control — allows you to choose key perfect key press zone, adjust rapid trigger sensitivity, assign different actions to different press depths, use a key as a digital or analog input on your Analog Keyboard.
